Beam - Unsupported beam compression flange
If you have a W12x16 beam supported on top plated columns at each end and the beam is 50'-0" lg., will the beam fail in bending if the only load on the beam is the weight of the beam itself? Assume there is no axial or lateral loads applied on the beam and that the unbraced length is the full 50'-0" length.
bjm
bjm
RE: Beam - Unsupported beam compression flange
1.81 LRFD
1.98 ASD
Deflection at midspan = 0.75 inches
...fails miserably.
