Replacing gear teeth
Hello. I am a welding foreman and have come across a dilema. On one of our hydraulic excavators, the ring gear (located in the swing/truck housing) is missing 4 teeth. The one single tooth that is missing is not as big as a problem as is the three in a row missing. Is it possible to replace the gear teeth by welding new ones in place? Is there anyone who makes just gear teeth or would my machine shop have to mill them? Any suggestions/proceedures that I need to aware of? I realize that 7018 electrode may not be sufficient, but would a 10018 electrode work? Or would I need to use a Ni-Cd electrode? What would the preheat/postheat temps be? I appreciate any help. Thanks!!
RE: Replacing gear teeth
On big slow speed gears - 1 NDP teeth, 10 rpm - welds are sometimes carried out as short term fixes while a new gear is made but generally welding teeth is not an option.
on heavy equipment where the gearteeth were
not induction hardened. Your gear teeth were probably
induction hardened for the hydraulic excavator.
Actually they built up the material rather than
welding a tooth and then used a template to control
a grinding operation to form the final teeth.
Very expensive. You might be able to go back to
the original builder and have them look at the
possibility of making a new geared ring for you.
I assume it is an internal gear. I would be greatly
concerned about the liability of welding the teeth
in place.
