Two questions: (1) Is there any
Two questions:
(1)  Is there any other way to get Mathcad 2000 into a word doc besides converting it to a rich file
(2)  I have had MathCAD solve extensive equations for a value 'c' and it gives the answer in a huge expression rather than a simplied number eg c = 10.  The simplfy command does not work... how do i get the value?
rather than solve, c > (10243/3423 + 84434^0.5)^0.5
for example
RE: Two questions: (1) Is there any
It sounds like you're using the Symbolic solver instead of the numeric solver.  If you use the normal "=" you should get only a numeric answer:
a:5
b:3
c:a*b
c=15
TTFN
