ASTM A252 Grade 3 Welding Process
Can anyone give me a reference for or tell me the welding process required for field splicing ASTM A252 Grade 3 steel pipe? Are there any special welder qualifications required? Any special welding electrode required? Any pre-heat, etc.?
RE: ASTM A252 Grade 3 Welding Process
2.) These piles are typically welded in accordance with AWS D1.1 on many projects. The A 252 Gr. 3 pipes are NOT prequalified per D1.1, Table 3.1.
Acceptance criteria for qualification:
D1.1 for piles 1/8" and greater
D1.3 for piles 3/16" and less in thickness
(yes they overlap)
3.) With P being the primary specified alloying element, preheat should be minimal (ambient temp. or 50 degrees F.)
Thank you for the quick response. Unfortunately, none of us has AWS D1.1. The pipe piles are 0.365" and 0.500" wall. We had proposed using an AISC B-U4b weld with E7018 electrode. We need some reference which will eliminate the need for a weld testing program. We need to address the non-prequalified issue. Any ideas?
While the joint is prequalified (B-U4b) using a single bevel and backgouging, the material itself is not in accordance with the D1.1. I have a letter from the former D1.1 chair stating if a material specification is not listed in Table 3.1, it is not a prequalified material, period. (sorry about the redundancy...)
If you are the EOR, you do have the authority to waive testing in accordance with AWS D1.1:2002, 1.4.1. You will also get to answer for any post-welding related problems or issues if any occur.
*When was the last time he/she tested using the SMAW process and F4 group electrodes?
*When was the last time he/she tested in the position used in production?
*When was the last time he/she tested without backing (open root)?
*Does the welder have experience on this type of material?
As a mimimum, I would recommend performing radiography (RT) on the first few production welds to ensure soundness of the welds. At least you will have incorporated some of the required testing specified for WPS qualification. It will also satisfy the performance qualification requirements for the welders (in lieu of bend testing).
2. In some technical write up I saw, since this material is not listed in AWS D1.1, they have aswked for this material to be welded considering it an equivalent to A572 Gr 50? Any thoughts on this.
3. If I were looking for a metrial substitute on basis of YS and UTS alone, I can use API 5L Grade B or A36. But is YS and UTS the only things to be considered for the applications that this material intended for namely piles......
An urgent reply would be appreciated.
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
email: sayee_prasad@yahoo.com
The black holes of nature are the most perfect macroscopic objects there are in the universe: the only elements in their construction are our concepts of space and time.
