Rib Sectioning
Rib Sectioning
I model and detail cylindrical cast parts with interior ribs with UG v18. the proper way to detail these ribs is with half scale hatching on the solid parts and full scale hatching on the ribs. Does anyone know of a more efficiant method to achive this than to use INSERT-->CROSSHATCH? Second, there seems to be an issue with manual crosshatching updating properly when there is a threaded throuogh hole involved in the section, is this a known issue and is there any way to fix it?
thanks.
thanks.
