Whell balancing machine
I need help to understand the vectors action in a L
configuration (two piezoelectrics, one radial and other
axial). I can measure amplitude and fase but now I need
information to calculate the corretion's mass for two
plane balancing.
Thank you
RE: Whell balancing machine
Hi RGFerreira
There is a Balance Software in www.denysschen.com.
It is very good.
Att
Mangua
rb1=vibA*tA1+vibB*tB1
rb2=vibB*tB2+vibA*tA2
all are vectors. * is vector multiplication, ie phase angles are added, moduli are multiplied.
rb = required balance, vib is the measured vibration, t is the influence vector or transfer function.
A is one accelerometer, B is the other. The corrections are applied at planes 1 and 2 on the wheel.
't's will be constant for a given wheel and tyre. I doubt that they can be determined analytically with sufficient accuracy.
Cheers
Greg Locock
mangua and GregLocock, thank you for your help,
every help is very good.
RGFerreira (Renato Gabelini Ferreira)
renatogferreira@uol.com.br
