Family Table Order
Family Table Order
Family Table Order
When making a Family Table, sometimes you need to insert an item before or after a certain column. You can use the swap option, but this is not quick, or export to Excel and reorder, but this is not quick also.
TIP:
Before you pick to include a new colum, just click an existing column in the family table, then add the new column. It will now appear to the right of it.
Steve
http://www.3dlogix.com
RE: Family Table Order
And another tip:
To sort the rows select a column for sorting and use command Tools - Sort - Ascending (or Descending). This makes the sorting temporary so next time you open the table it is not sorted.
To make the sorting permanent select the sorted instances (rows) and use command Tools - Lock/Unlock Instance twice.
