Top Tray Spacing Criteria in a Column
Hi ALL!
What would be the criteria for the separation of the top tray and tangent line in a stripper column?
Can I assume a 24-36" spacing for this tray to allow a proper disengagement? (Column Diameter is approx. 3 ft)
Is there any quantitative criteria (i.e. 0.5 x Column Diameter) to determine what would be the height I should leave in this top tray?
Any help is welcome.
ChemE2912
ChemE2912
RE: Top Tray Spacing Criteria in a Column
Most engineering companies use 900mm-1000mm as a general distance for this top tray and tangent line.
This is rather quite specific to above situation.
I suggest referring Distillation books by Kister before making any decision.
Thank all.
