Minimum Gear Diameter
Greetings,
Being an aerospace design guy, with zero gear design experience, I am stumped with my latest task.
I am trying to get a feel for the size of a 90 degree gearbox to go into a turboprop aircraft. The horsepower of the engine is ~240 shp max, and the output shaft RPM from the engine is 3000. I need to step this up in the 90 degree gearbox to 7,600 RPM. And of course I have to do this using the least amount of volume possible. Obviously, I need to minimize the gear diameter to minimize the gearbox housing dimensions.
Right now, I just need a rough set of dimensions to put in the CAD model (i.e. 6"x8"x8").
Can someone explain to me the relationship between horsepower (or torque if you'd like), RPM and minimum gear diameter?
Any help will be greatly appreciated.
Best regards,
Grant Wittenborn
Best regards,
Grant Wittenborn
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
RE: Minimum Gear Diameter
Can you tell me where to get a catalog?
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
http://www.globalspec.com/Supplier/OnlineCatalog/ArrowGear/?se=av
I figured I could look all that information up, so you don't have to waste your time. I just needed a place to start.
Thanks again for the source and info.
Grant
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
