Help needed..Intermittent fault with leader lines in AutoCAD 2000
If you use match properties on the leader line and a block in the same
selection set, it will often explode the block and the leader line.  If I
try undo to reverse the process the block and leader line (now reblocked)
appear at the top limit of the drawing.  On trying to replace the two items
in the correct position, the insertion point of these and other subsequent
blocks seems to be relocated at 0,0.  I have tried reinstalls to no avail.  Any suggestions please???
