First Use of Threads
One of my colleagues was wondering aloud when the first threads were used for mechanical fastening, clamping, or positioning.
The first "thread" use I thought of was Archimedes and his screw-pump but he was thinking about threaded fasteners or power screws.
Anybody know?
Anybody know?
RE: First Use of Threads
I remember reading the following tidbits.
Metal fasteners didn't start to show up until around the 15th century but did not become common until the industrial revolution in the 19th. The story I remember is that before machines were created to produce repetitive threads they were hand filed and the nuts were tied with a string to the bolts that they fitted. I.E. they were only used on large structural projects like bridges where their ease of use outweighed their difficulty to manufacture.
One Good Turn - A natural history of the screwdriver and the screw by Witold Rybczynski.
http://www.amazon.com/exec/obidos/search-handle-form/103-2273759-3479857
I haven't read it, but it should answer a few questions. The extracted pages from it on Amazon are from the introduction and index rather than the body of the book, so they're pretty unhelpful in judging its content.
Does a corkscrew count?
Another field where they might show up earlier is jewellery. I could ask my brother the archaeologist.
looking through the sample index pages of that book it looks like it'll have all the answers - I'm not ordering it - the postage will be twice what the book costs!
Cheers
Greg Locock
The only naturally-occurring screw is the DNA double-helix, which could never have been discovered without first the invention of precision screws. So we imagined the shape, then we found it occurring naturally.
Hopefully not too off-topic.
Brad
Out of the clear blue sky I stumble on a thread that reminds me of something I haven't thought about in years. I asked this question of the curator of a machine tool museum in the Massachusetts/Rhode Island Blackstone River Valley. This is the birthplace of the Industrial Revolution in the United States. He didn't have a good answer, but I suspect someone out on this list will know. Here goes.
Many of us have probably cut our share of lead screws and know it's not too difficult with a decent lathe fitted with a good lead screw.
The big question for me is "How the heck did they fabricate that first "good" lead screw?
My guess is that it wasn't too difficult to turn a uniform cylinder and to lay out a right triangle on a piece of paper and wrap that aroumd the cylinder. That would give a decent layout, but how was the thread cut? Probably by hand with a file, but would this give enough accuracy? Would this screw being used to cut a second screw "filter" out some of the imperfections and would repeating the process a few times with these theoretically, progressively better screws finally result in an acceptable lead screw?
I'm not losing any sleep over this, but would like to know the answer if anyone out there does.
Thanks in Advance.
In this case, I would suspect that it was ground or filed although I can picture how it might have been cast. I think casting's been around for a long, long time and it would be much easier to cut that first lead screw into clay or something.
Cheers
Greg Locock
JC
Cheers
Greg Locock
So it would seem that some of the methods mentioned above would work very well. A practised craftsman could file a very accurate thread chaser and then file an accurate initial groove on a rod.
The question of how machine tools became progressively more accurate, despite having only less accurate machines to make them, is quite interesting and would make another good thread.
The addition of back gearing, lead screw, and roller bearings on a lathe was a great leap forward in the machine shop. In the 20's to make a very precise lead screw a very simple method was used to average out imperfections. The very best lead screw was made on a lathe and it it turn was installed a lathe and a follower made with leather was used to make another lead screw. Some of the original ruling engines used this approch to make very fine lines for diffraction gratings.
I have seen some amazing work done on machinery I thought was totally worn out. It was the machinist not the machinery.
Here is the history of the screw according to
http://inventors.about.com/library/inventors/blscrewdri...
TTFN
http://www.hayesbolt.com/news%2C_seminars%2C_events.htm
Perhaps Ms. Bellis' article was mis-edited and should have said "only appeared in large quantities in the 15th century"
TTFN
http://www.findarticles.com/cf_dls/m1026/5_158/67161980...
TTFN
BBC TV have a series "What the Romans did for us", that includes an item on making a reproduction Roman wine press, with an enormous wooden screw to compress the grapes. I can't vouch for the original evidence, but the whole point of the series is Roman Technology. The modern screw was cut by hand by some woodworking specialists, using technology available to the Romans.
My point is that the screw, and screw making techniques were available as long ago as that, and would transfer to metal as soon as that technology improved. The use of fine thread screws would have had to wait until steel was available, after the Industrial Revolution. Cast iron would be too brittle.
In "Foundations of Mechanical Accuracy" published by Moore Tools, there's a nice description of making precision lead screws. The final step is hand lapping.
Laps are devices that average out errors, so if you have a screw with decent overall accuracy but local errors, a lap (skillfully operated) will improve it.
