ByVal behavior in API acts like ByRef?
I am a little confused by the behavior of ByVal as it applies to declaring API functions. I thought ByVal was supposed to prevent a function from changing the value of an input parameter. However, it seems that this is not true, given the behavior of some API calls that I have cut-and-pasted into my programs.
I don't know why this is so. It has been working fine, so I just believed and let it be. Now I'm overcome with curiosity.
An example is below. This is pasted from MS knowledge base. The function SHGetPathFromIDList uses ByVal, but the function is still able to change the input parameter lpBuffer.
Pasted code below:
Option Explicit
Private Const BIF_RETURNONLYFSDIRS = 1
Private Const BIF_DONTGOBELOWDOMAIN = 2
Private Const MAX_PATH = 260
Private Declare Function SHBrowseForFolder Lib "shell32" _
(lpbi As BrowseInfo) As Long
Private Declare Function SHGetPathFromIDList Lib "shell32" _
(ByVal pidList As Long, _
ByVal lpBuffer As String) As Long
Private Declare Function lstrcat Lib "kernel32" Alias "lstrcatA" _
(ByVal lpString1 As String, ByVal _
lpString2 As String) As Long
Private Type BrowseInfo
hWndOwner As Long
pIDLRoot As Long
pszDisplayName As Long
lpszTitle As Long
ulFlags As Long
lpfnCallback As Long
lParam As Long
iImage As Long
End Type
Private Sub Command1_Click()
'Opens a Treeview control that displays the directories in a computer
Dim lpIDList As Long
Dim sBuffer As String
Dim szTitle As String
Dim tBrowseInfo As BrowseInfo
szTitle = "This is the title"
With tBrowseInfo
.hWndOwner = Me.hWnd
.lpszTitle = lstrcat(szTitle, "")
.ulFlags = BIF_RETURNONLYFSDIRS + BIF_DONTGOBELOWDOMAIN
End With
lpIDList = SHBrowseForFolder(tBrowseInfo)
If (lpIDList) Then
sBuffer = Space(MAX_PATH)
SHGetPathFromIDList lpIDList, sBuffer
sBuffer = Left(sBuffer, InStr(sBuffer, vbNullChar) - 1)
MsgBox sBuffer
End If
End Sub
Pasted code below:
Option Explicit
hWndOwner As Long
pIDLRoot As Long
lpszTitle As Long
ulFlags As Long
lParam As Long
iImage As Long
End Type
With tBrowseInfo
End With
If (lpIDList) Then
MsgBox sBuffer
End If
End Sub
All this machinery making modern music can still be open-hearted.
RE: ByVal behavior in API acts like ByRef?
see http://www.tek-tips.com/gviewthread.cfm/lev2/4/lev3/32/pid/222/qid/640085
Basically, ByVal will behave like ByRef in Windows API due to differences between how strings are defined in C vs. VB.
