How to eliminate linear bearing noise?
I have a reciprocating shaft running in two plain bearings (bushings). The shaft reacts a moment and the bearing pressures are significant (2000 psi). The shaft movement is about 5/16". I have a 16 uin surface finish (I think) but the thing sounds like a zipper during shaft movement. What surface finish will I need to eliminate the zipper sound?
RE: How to eliminate linear bearing noise?
Ra <= 0.0004 mm and Rz <= 0.003 mm.
When smooth running is of particular concern:
Ra <= 0.0003 mm and Rz <=0.002 mm.
