How to design the slab in slab-wall structure using ETABS results?
I have used shell element to model the floor slab in the structure and assigned automatic mesh options to it. I am quite satisfied with the overall outcome of the building. Now I am going to do the slab design. Since ETABS does not have the function of slab design, I want to export from ETABS a single storey in SAFE format and do slab design in SAFE.
My question is that since I have used shell element in overall analysis of the building, there exists stresses and forces in the slab under lateral loads, will these stresses and forces be considered in SAFE?
RE: How to design the slab in slab-wall structure using ETABS results?
I believe that CSI should had incorporated slab design in ETABS. However, they must had considered the marketing of SAFE in advance, therefore slab design was not included in ETABS.
Such limitation, in fact, poses a major problem when the slabs are to be design to resist lateral forces (ie, wind and seismic forces) as the resultant stresses cannot be exported to SAFE for slab design, and only gravitational loads can be conveniently defined in SAFE.
To account for the resultant moments and shears due to lateral forces, the horizontal applied force (ie momments and shears of vertical structural elements that resist lateral force) from dynamic / wind analysis must be transfered manually. That is really tedious and inefficient.
Please note that DYNAMIC analysis results can not be exported to SAFE since SAFE is not a dynamic analysis program. However, if you define Auto Lateral Loads in the Static Load Cases (Using one of the many codes supported by ETABS), those lateral analysis results will be considered in the slab or foundation design. Please try it.
Amadeus
