Designer seeking Mfg. input
Gentlemen,
Can an EDM process be used for producing a sharp inside corner (.002 max R) within a blid hole?
The hole is about 3.5" diameter and 3.5" deep.
Thanks for the help!
djk
djk
RE: Designer seeking Mfg. input
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Why do you need a .002 max radius in a blind hole?
I'd like to be able to eliminate a leak path and save money by making the pump a two piece design. I.E. one housing with blind hole and one end cover. A sharp corner is required to help prevent an inefficient pump.
Are you planning on using a graphite or copper electrode?
I was really just wondering about process capability. I googled all over for edm references but found nothing concerning sharp corners within blind holes.
thanks all.
