Building Simple LED circuit
Im trying to design a LED lighting kit for a model car. I want to use the following LEDs in it:
4 White Super LEDs
Forward Voltage - 3.4 V Typical (max 4.0)
Forward Current - 30 mA
and 4 Super Red LEDs
Forward Voltage - 2.1 V Typical (max 2.5)
Forward Current - 50 mA
I will be running these of a dedicated NiCD battery pack. These LEDs will be continuously running when on. I would greatly appreciate any design help that anyone could offer me.
Thank you for your time and patience.
4 White Super LEDs
RE: Building Simple LED circuit
Connect all the LEDs of a color in parallel, connect red LEDs between common and the the junction between the 2nd and 3rd batteries, white cells between the common and +ve of the third. Perhaps a low value resistor for each branch to ease the voltage a bit.
Good luck,
Engin
The resistor value is R=V/I where V is the voltage across the resistor. V = (Vbatt - Vled) The resistor power is V x I where I is the current through the resistor. Choose a resistor with twice the power rating as the calculated power above. That will keep it cooler, and give the resistor some air to dissipate the heat.
Try Maxim, TI, etc. for LED driver chips, application notes and to request samples. This technology is rapidly growing right now.
