Storm Water Pollution Prevention
Does anyone know of any data or research that shows if the storm water pollution prevention being done on construction sites is of any value to the environment? I believe that so many of the SWPPP practices are a waste of money. Any thoughts?
RE: Storm Water Pollution Prevention
Please see FAQ731-376 by VPL for tips on how to make the best use of Eng-Tips Fora.
How about going after the perennial bigtime polluters like agriculture, power plants, heavy industry and gas guzzling SUV drivers? The new phase 2 requirements for smaller cities could do quite a bit, although it will be a huge tax burden.
I suppose the relevance and value will be different, depending on whom you are asking. If you ask a fish cop, the absence of deliterious materials introduced into habitat (cloudy water, etc.) is an absolute value. To the project manager or Owner, it is a matter of higher cost. To the contractor, it is an opportunity to make more money, or an inconvenience.
Personally, mother nature can put up with dirty water in a reasonable fashion. Up here the fish cops can arrest and carry handguns and cuffs, so while I believe they carry their juridiction way too far, I am forced to respect them and not argue too much!
Much of the temporary requirements, I feel, are a complete waste of money and are of absolutely no benefit to the overall environment. In fact, in some cases, the installation of some barriers and measures creates more problems than they solve. That being stated, I do know that the fish cops do not agree with me.
KRS Services
www.krs-services.com
The problem is that some agency reviewers often expect and engineers often write/draft/design the same standardized boilerplate stuff on every project, whether it makes sense or not. For example, some agencies won't approve TESC plans if Straw Bale Barrier notes are not included, even if there is no where to put Straw Bale Barriers on the site. And I've reviewed TESC narratives by colleagues where they copied verbatim from another project (hey, you have to remember to change the project name!). I encountered this frequently with road projects, which have some different issues than site development. This kind of boilerplate approach could be counterproductive, in my opinion, because it makes it hard for contractors to discern what type of SWPPP practices are clearly beneficial and important for resource protection, versus those that are required just so the reviewer will issue the permit and feel that the agency's liability is minimized.
cvg really brings up a good point, and you know how our beloved fish cops have responded?....they insist that barriers and screens be erected onto bridges so that any substances from a birdge flush will be caught.
The result...many bridges are no longer flushed and relay on a few melts or heavy storms to "wash" the deliterious material into a stream.
Same goes for the chlorides (road salts) as now being labelled as "toxic substances" by the Ministery of Environment!
KRS Services
Did this allow a higher quality of fish to exist, or improve any recreational or water uses? Probably not, but the measures are effective based on measurable parameters.
I disagree with CVG in the above posts:
"How about going after the perennial bigtime polluters like agriculture, power plants, heavy industry and gas guzzling SUV drivers"
First of all, power plants and heavy industry are subject to stormwater regulations, and I would argue they carry a larger regulatory burden than construction. Exemptions to agriculture are eroding (pardon the pun) and will be regulated soon enough. SUV drivers??? that's just plain irrelevant and provocative!
Anyway, the SWPPP as a document is not so important at the tasks of implementation and critical evaluation and re-design. Done diligently, improvements can occur. The unfortunate part is that it is having to occur under a regulatory program usually results in one size fits all approaches.
1. The burocrates that dream up most of these regulations should be made to produce a realistic cost/benifit analysis of the consequences of the rule. IMHO many of them would be found to be too costly by any streach, for the benifit they MAY have. Feel good, make work programs are too costly in today's world.
2. CVG's comments are off base. First of all, the power industry has made huge strides in cleaning up their act - by force yes, but progress none the less. The same can be said for the car industry. As far as agriculture, it depends a lot on the State you are in. In Wisconsin great changes have been made, not just by State mandated requirements, but working arrangements with groups like Trout Unlimited. Working with sportsman's groups like TU doesn't spend tax dollars, but produces results without costing the farmer an arm and a leg either.
Frankly, I get tired of the same old environmental mantra. I think some of the enviromental movements would get farther with a positive approach rather than the same old, tired confrontational approach. There has been a lot of progress over the last thirty years, how about giving credit where credit is do? And, how about recognizing that people have to make a living too? They would get a lot farther with a balanced approach, IMHO.
I know it will never happen, but just once I would love to see regulations enforced with a degree of moderation and qualifying expertise and understanding of the overall impacts of construction with a corresponding balance and care practiced by the contractor. If this should ever occur, perhaps then, all stakeholders will be satisfied and happy with the nature of the job to be done!
That's 'nuff of my rambling and philisophical stew!
KRS Services
They have issued the TPDES General Permit TXR150000 (Construction) that is fairly definitive of what is required for SWPPP's.
Permit available at
http://www.tnrcc.state.tx.us/permitting/waterperm/wwperm/construct.html#approved
As a PE & CPESC, I do not find the burden of preparation and implementation excessive. If done properly, the erosion & sediment controls can be effective and fairly economical. Having worked in the northeast for 5+ years during the late 80's, I find that Texas is still lagging as far as environmental concerns. Elimination of tracking dirt/mud onto pavement, control of dust and minimization of polluted runoff does make a large difference in stream pollution, especially in a city with major construction projects.
The Trinity River runs through the center of Dallas and is very polluted.
Check this web site for Texas impaired waters.
http://www.texasep.org/html/wql/wql_1swq_303d.html
