AutoCAD CAO and VBA problem
I have wrote VBA project for automating some autocad tasks. But VBA
project's behavior differ from time to time i run it.
There the code:
                        Dim CurrentLinks As CAO.Links
                        Dim ObjectIDs(0 To 0) As Long
                        ObjectIDs(0) = CurrentCircle.ObjectID
                        Set CurrentLinks = dbConnect.GetLinks(CurrentLinkTemplate, ObjectIDs, CAO.kEntityLinkType)
                        Dim msgString As String
                        If CurrentLinks Is Nothing Then
                            Call PanToObject(CurrentCircle, c_Magnfication_Error)
                            Initialize = False
                            Exit Function
                        End If
                        If CurrentLinks.Count <> 1 Then
                            Initialize = False
                            Exit Function
                        End If
Each linked autocad entity have only 1 link. But some times i run
script it finds more than 1 links for some objects. But when i choose (dbConnect->Links->Links Manager)
for such object i can see only 1 link.
Is this is a bug in CAO library or my mistake?
