Convert solidworks models into pro-e models
hi,
my question is how to convert solidworks models into pro-e models.
anybody respond
thanx
anybody respond
thanx
RE: Convert solidworks models into pro-e models
- save your SW model as a Pro/E file (File>Save As in SW)
- Import your SW model into Pro/E (File>Import in Pro/E)
Be advised though that you'll loose a certain amount of data.
Cyril Guichard
Mechanical Engineer
Save the model in SW as STEP.
Open or import the STEP file in Pro/E.
Note that the file extension for Pro/E must be .stp but SW will use .step so it must be changed.
This will transfer the model geometry but not the features.
(You see only "imported geometry" in the model tree).
Cyril Guichard
Mechanical Engineer
