Calculate bottle cavity volume or other non uniform cavity volume
How to calculate the volume of a bottle or other non uniform cavity volume for proe model ?
Thankyou.
Thankyou.
RE: Calculate bottle cavity volume or other non uniform cavity volume
let me know how it works out for ya.
And can u explain more about the behavior moddlling method ? can i do it with normal proe , or do i need extra module from ptc ?
Thanks.
Regard chris
Behavioural modeling... extra $$$. You need to incorporate this method from the get go.
You will get your answer faster with the first technique
Did you create the innver volume of your bottle?
Good luck, happy modeling :)
It will be very nice of u to show me the way.
For the previous one using model analysis ,it onli get the volume of the bottle solid model, i actually want to know about the cavity volume.
Thankyou all.
Since I don't know what your working on, I will assume it is a complex bottle shape like a Coke bottle.
1.) The first thing you must do is create 2 models. The first model your existing hollow bottle and a second bottle exactly the same as the first but with the interior filled in (not hollow). Use the "save as" function to achieve this quickly.
2.) Next create an assembly. Assemble both bottles (the filled and the hollow) one on top of each other. Since the models are save as models accepting the default for assembly constraints will work fine.
3.) In the assembly just created pick - Component - Adv Utils - Cut Out
4.) Pro will prompt you to select the model to perform the Cut Out process to. Use Query select to select the 2nd bottle (the solid one). You must hit done select because you can pick more than one model.
5.) Pro will now prompt you for the reference parts for cut out process select the 1st bottle (the hollow one). Then done select.
6.) The cut out has now been performed. If you now look inside the 2nd bottle file (the solid one) you will notice the cut out feature in your model tree. You will also notice that you are left with the internal solid of the bottle.
7.) Run your mass props in this file to find your volume.
8.) Punch out for day and have a beer, you've done your job.
This method hardly uses Pro/E's capabilities, but can usually be done faster than any other approach I have tried
