Eliminating Recoil
Eliminating Recoil
I work for a company that has researched and developed a new generation recoilless device. We are currently at the stage where some of our financial backers are seeking some information to further our funding. The hand held and bench prototypes have been built and the handheld has been test fired by representatives of some government representatives.
Can anyone provide me with some data to further this?
Specifically:
Small Arms expenditure for the US, Taiwan, UK, Turkey and Israel (including Longarms)for the most recent fiscal year
Heavy Weapons expenditure for the the US, Taiwan, UK, Turkey and Israel
Number of small arms in circulation in the US, Taiwan, UK, Turkey and Israel
Any studies on recoil that are public domain (there is a shortage of stuff on the web)
Any studies or published articles that (independantly) articulate the benefits of eliminated or substantially reduced recoil.
Thanks in advance all...
gary
Group Operations Manager
Recoilless Technology International
RE: Eliminating Recoil
Try the "Governmental Part" of the Google search engine: http://www.google.com/unclesam
Another good source of information on military issues is the FAS http://www.fas.org/.
-Juerg Hoelzle-
Juerg Hoelzle
juerg.hoelzle@ruag.com
http://www.ruaglandsystems.com
http://www.ruag.com
Re your own weapons systems linked to the web site. Are you a systems developer as well...?
regards. gary
Over the last 15 years I have done a lot of work for UK MoD and defence industry on recoil management including benefits and tech solutions (mostly for 155 artillery).
I will dig some reports out and see if they are public domain or can be declassified. If you post your e-mail address that would be easier than using this forum. What country are you in?
A growing benefit of recoil management is the need for big guns on lightweight (airporatble) vehicles.
John
What kind of gun is it used for? A small arm or ...?
What principle is used? Muzzle-break, Jet-chamber or ...?
Give me some more information!
Andreas Nehme
mail@waffentechnik.com
Although the article is not on-line yet, Machine Design Magazine (www.machinedesign.com) has the following article on "friction springs"
Frictions Springs Put a Damper on Things
By Carl Fenstermacher
Machine Design
23 October 2003
Page 62
The author is from Ringfeder Corp. (www.ringfeder-usa.com)
Here are images of Recoil mechanisms from their website:
30 mm Cannon
35_50mm Chain gun
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
This shows only standard design. For advanced users try
http://www.roehrs.de/daempfungselemente.htm
It is the best for gun-relevant demands!
Andreas Nehme
Was there ever a consideration of moving the turret with the weapon to overcome recoil that you know of?
Greg
Yes this has been investigated. Clearly, the best antidote to recoil is mass, and turrets are heavy. However, there are usually crew in the turret, and they would get thrown about. Also the difficulty of a sliding as well as rotating turret ring bearing is problematic.
In general, the problem is increased firepower on lighter platforms, which challenges the laws of physics. There are clever techniques such as soft recoil, which can alleviate this at the expense of some operational problems.
John
How about using a different mechanical solution to turret movement then the ring bearings?
Greg
