Dwg rebuild help
Dwg rebuild help
Dwg rebuild help
I have a large dwg with a lot of detail. I created two broken out views from a view on sheet 1 and moved them to sheet 2 because of space. Now whenever I open this dwg, there is the green lights (rebuild) next to the two views on sheet 2 and never go away. Is this a bug, or is there a trick to fix this??
thanks
RE: Dwg rebuild help
ctopher,
I have this happen too.  Sorry, I do not have a fix.  I will be interested to see if someone else does.
Regg
If Sheet 1 is Open (also), and you rebuild it (no greenies on Sht 1), does the lights on Sht 2 go out after a rebuild?
Mr. Pickles
Sometimes they go out, if they do..the ones on sht 1 go on. They switch back-and-forth. There is always greenies on either sht at all times. Frustrating!
What I have done in the past is to insert the same drawing view I had on Sht1 onto Sht 2.  Then I pull my details from the view on Sht 2, then hide the duplicate view so only the view on Sht 1 is visible.
Was that confusing?
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
MadMango,
No, not confusing. I'll try it, thanks for the tip
We have seen something similar in the past.  It appeared to be related to the time dependencies when views are created from others and the sheets they are on.  There did seem to be some logical reasoning to it.  It that case we found that opening and saving the sheet in the appropriate order fixed it.  On the other hand we also decided for our purposes that as long as the currently open sheet was up to date it did not really matter and that in fact, although the other sheets might indicate they THOUGHT they needed a rebuild, nothing had infact changed in them.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
