Blocks or Pattern Files for SAE hydraulic pipe flanges
Are there links available where I can download blocks/pattern files of the standard SAE pipe flanges? For example, 1" SAE 3000 or 6000 psi series flange - hole and bolt dimensions, general dimensions etc. This would help in designing manifold blocks etc, otherwise one would have to re-create all standards if one doesn't have a dedicated package. Any help/links would be appreciated.
Dunewambo
RE: Blocks or Pattern Files for SAE hydraulic pipe flanges
What kind of cad system you using dunewambo?
Hi AlexDring
Am using AutoCAD 2000, so nothing fancy at all. Will be upgrading to 2004 soon. I just basically need the drawing files of the standard SAE porting details to insert into drawing/designs.
