Winding connection question.
Rewinding a single phase motor. Original winding - run = one in hand (or two in hand), start = one in hand. Replace run with two in hand, and start with two in hand - or one in hand in both, and parrellel connections. Motor contains centrifigul switch, also a motor does not contain a cent. switch.
Once motor is running, could the start windings act as a transformer, due to the parrellel connections? Or could there be any other implications with these windings? We have debated this for sometime, partly due to the fact that when we rewind motors in this way, which i shall add we are hesitant to do, and have had problems in the past with the motor overheating, or just not running. Also - certain motors contain capactitors, weather start - run or both. Reason for winding two in hand, or using parrallel connection - original wire used is too heavy to rewind - not practical.
Any further information req'd, let me know, otherwise i am extremly interested in hearing some thoughts about this. Thanks Adrian
RE: Winding connection question.
PS
I ran into a similar problem trying to reconnect a two speed two winding motor for low voltage!
