AC2004, ET, "txtexp" is faulty
the command "txtexp" , Expresstools, is not working exactly . The exploded text is not at the original insert-point. The letters are wrong: h-> Arial, or S-> Simplex...
Did anyone solve this problem with the "txtexp.lsp"???
Thanks for reply,
Lothar
RE: AC2004, ET, "txtexp" is faulty
You could try copying the textexp.lsp file from a previous version of express tools and swapping that with the one you currently have - that one works fine. If that doesn't work then try using normal explode to dtext first; this will remove any properties that textexp.lsp may not recognise as it was writtn before 2004's updated mtext - and then using e/tools?
sorry that should be txtexp.lsp!
Hi cadshite,
it's not working. The "txtexp.lsp" from ETV1-9 is still identic in ET2004...
Here it is:
;;;    By Dominic Panholzer
;;;    TXTEXP.LSP
;;;    Copyright © 1999 by Autodesk, Inc.
;;;    Your use of this software is governed by the terms and conditions of the
;;;    License Agreement you accepted prior to installation of this software.
;;;    Please note that pursuant to the License Agreement for this software,
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;;;  External Functions:
;;;     ACET-ERROR-INIT           --> ACETUTIL.FAS   Intializes bonus error routine
;;;     ACET-ERROR-RESTORE        --> ACETUTIL.FAS   Restores old error routine
;;;     ACET-GEOM-ZOOM-FOR-SELECT --> ACETUTIL.FAS   Zoom boundry to include points given
;;;     ACET-LAYER-LOCKED         --> ACETUTIL.FAS   Checks to see if layer is locked
;;;     ACET-GEOM-PIXEL-UNIT      --> ACETUTIL.FAS   Size of pixel in drawing units
;;;     ACET-GEOM-TEXTBOX         --> ACETUTIL.FAS   Returns the textbox for any text
;;;     ACET-GEOM-MIDPOINT        --> ACETUTIL.FAS   Returns midpoint between two points
;;;     ACET-GEOM-VIEW-POINTS     --> ACETUTIL.FAS   Returns corner points of screen or viewport
;;;     ACET-STR-FORMAT           --> ACETUTIL.ARX   String builder
;;;     ACET-WMFIN                --> ACETUTIL.FAS   Brings in WMF file
(defun c:txtexp (/ grplst getgname blknm FLTR GLST GDICT SS VIEW UPLFT TMPFIL TBX
                   TMPFIL CNT PT1 PT2 ENT TXT TXTYP PTLST ZM LOCKED GNAM vpna vplocked)
  (acet-error-init
        (list
         (list   "cmdecho" 0
                 "highlight" 1
                 "osmode" 0
                 "Mirrtext" 1
                 "limcheck" 0
         T
; --------------------- GROUP LIST FUNCTION ----------------------
;   This function will return a list of all the group names in the
;   drawing and their entity names in the form:
;   ((<ename1> . <name1>) ... (<enamex> . <namex>))
  (defun acet-txtexp-grplst (/ GRP ITM NAM ENT GLST)
    (setq GRP  (dictsearch (namedobjdict) "ACAD_GROUP"))
    (while (setq ITM (car GRP))       ; While edata item is available
      (if (= (car ITM) 3)             ; if the item is a group name
        (setq NAM (cdr ITM)           ; get the name
              GRP (cdr GRP)           ; shorten the edata
              ITM (car GRP)           ; get the next item
              ENT (cdr ITM)           ; which is the ename
              GLST                    ; store the ename and name
                  (if GLST
                    (append GLST (list (cons ENT NAM)))
        (setq GRP (cdr GRP))          ; else shorten the edata
    GLST                              ; return the list
; ------------------- GET GROUP NAME FUNCTION --------------------
;   This function returns a list of all the group names in GLST
;   where ENT is a member. The list has the same form as GLST
  (defun acet-txtexp-getgname (ENT GLST / GRP GDATA NAM NLST)
    (if (and GLST (listp GLST))
      (progn
        (foreach GRP GLST
          (setq GDATA (entget (car GRP)))
          (foreach ITM GDATA                   ; step through the edata
            (if (and
                  (= (car ITM) 340)            ; if the item is a entity name
                  (eq (setq NAM (cdr ITM)) ENT) ; and the ename being looked for
              (setq NLST                       ; store the ename and name
                      (if NLST
                        (append NLST (list (cons (car GRP) (cdr GRP))))
    NLST
;                          MAIN PROGRAM
  (if (and                                                ; Are we in plan view?
        (equal (car (getvar "viewdir")) 0 0.00001)
        (equal (cadr (getvar "viewdir")) 0 0.00001)
        (> (caddr (getvar "viewdir")) 0)
    (progn
      (prompt "\nSelect text to be EXPLODED: ")
      (Setq FLTR    '((-4 . "<AND")
                        (-4 . "<OR")                      ; filter for mtext and text
                          (0 . "MTEXT")
                          (0 . "TEXT")
                        (-4 . "OR>")
                        (-4 . "<NOT")
                          (102 . "{ACAD_REACTORS")        ; and not leader text
                        (-4 . "NOT>")
                      (-4 . "AND>")
            GLST     (acet-txtexp-grplst)                             ; Get all the groups in drawing
            GDICT    (if GLST
            SS       (ssget  FLTR)
            CNT      0
      ;; filter out the locked layers
      (if SS
        (setq SS (car (bns_ss_mod SS 1 T)))
      ) ;if
      ;; if we have anything left
      (if SS
        (progn
          (setq CNT 0)                                 ; Reset counter
          (while (setq ENT (ssname SS CNT))            ; step through each object in set
            (and
              GLST                                     ; if groups are present in the drawing
              (setq GNAM (acet-txtexp-getgname ENT GLST))          ; and the text item is in one or more
              (foreach GRP GNAM                        ; step through those groups
                (command "_.-group" "_r"               ; and remove the text item
                  (cdr GRP) ENT ""
            (setq TBX (acet-geom-textbox (entget ENT) 0))   ; get textbox points
            (setq TBX (mapcar '(lambda (x)
                                 (trans x 1 0)         ; convert the points to WCS
                        TBX
            (setq PTLST (append PTLST TBX))            ; Build list of bounding box
                                                       ; points for text items selected
            (setq CNT (1+ CNT))                        ; get the next text item
          ); while
          (setq PTLST (mapcar '(lambda (x)
                                 (trans x 0 1)         ; convert all the points
                               )                       ; to the current ucs
                      PTLST
          (if (setq ZM (acet-geom-zoom-for-select PTLST))          ; If current view does not contain
            (progn                                     ; all bounding box points
              (setq ZM
                (list
                  (list (- (caar ZM) (acet-geom-pixel-unit))     ; increase zoom area by
                        (- (cadar ZM) (acet-geom-pixel-unit))    ; one pixel width to
                        (caddar ZM)                    ; sure nothing will be lost
                  (list (+ (caadr ZM) (acet-geom-pixel-unit))
                        (+ (cadadr ZM) (acet-geom-pixel-unit))
                        (caddr (cadr zm))
              (if (setq vpna (acet-currentviewport-ename))
                  (setq vplocked (acet-viewport-lock-set vpna nil))
              );if
              (command "_.zoom" "_w" (car ZM) (cadr ZM))  ; zoom to include text objects
          (setq VIEW     (acet-geom-view-points)
                TMPFIL   (strcat (getvar "tempprefix") "txtexp.wmf")
                PT1      (acet-geom-midpoint (car view) (cadr view))
                PT2      (list (car PT1) (cadadr VIEW))
          (if (acet-layer-locked (getvar "clayer"))       ; if current layer is locked
            (progn
              (command "_.layer" "_unl" (getvar "clayer") "")  ; unlock it
              (setq LOCKED T)
          (command "_.mirror" SS "" PT1 PT2 "_y"
                   "_.WMFOUT" TMPFIL SS "")
          (if (findfile tmpfil)                           ; Does WMF file exist?
            (progn
              (command "_.ERASE" SS "")                   ; erase the orignal text
              (setq ss (acet-wmfin TMPFIL))               ; insert the WMF file
              (command "_.mirror" ss "" PT1 PT2 "_y")
            ) ;progn
          ) ;if
          (if LOCKED
            (command "_.layer" "_lock" (getvar "clayer") "") ; relock if needed
          ) ;if
          (if ZM (command "_.zoom" "_p"))              ; Restore original view if needed
          (if vplocked
              (acet-viewport-lock-set vpna T) ;re-lock the viewport if needed.
          );if
          (prompt (acet-str-format "\n%1 text object(s) have been exploded to lines."  CNT))
          (prompt "\nThe line objects have been placed on layer 0.")
    (prompt "\nView needs to be in plan (0 0 1).")
  );if equal
  (acet-error-restore)                                  ; Retsore values
  (princ)
(princ)
Thanks for reading,
Lothar
