Section View in Draft Mode
Hi everybody,
Can anybody help me to solve this problem.
When a cutting plane is created in different levels,the change in level is shown as a thick line in the section view. Is there any way to change this default line to other type of lines like chain line. I know I can change the styles in the format command,but specifically how to change this cutting plane problem?
RE: Section View in Draft Mode
There may be an easier way, but this works and was the fastest solution I have.
I'll check further into it.
Can you please check the thread
Thread562-68105
Please send me your email id so that I can mail you the part file.
Click here to see the image where I need to change the two lines as marked.
http://www.zacknetwork.net/eyedea/section.jpg
