I have an array of values and am using the VLOOKUP function to pull the appropriate values from my table so I can run some calculations using those variables.
The problem I'm having is that the values being extracted by VLLOKUP are the *exact* values listed in the array, but I would prefer values that have been linearly interpolated. How can I do this?
Thanks, Greg. That thread is just what I'm looking for!
I'm very surpised to learn that Excel doesn't have such a function. I was hoping that maybe there was some add-in or something that I missed that would this, but apparently there isn't.
I'm not sure what you are working with, but with your sheet can you make several columns and do the vlookup as column 1, column 2 etc.??? This could return several answers for a single problem. It then depends on how you write the formulas in the array or columns that you are looking up.
I'm not that good at explaining so I hope this makes since and helps.
Not sure why VLOOKUP is suggested for interpolation I always use the following function for interpolation.
regards, athomas236
Function Interp(X, Y, Xe) ' This function interpolates and extrapolates linearly on ' arrays of X and Y values ' Input is as follows ' Array of X values that are in a sequence of increasing values ' Array of Y values ' Value Xe for which value of Y is required
' Count number of X values For Each Item In X CountX = CountX + 1 Next Item
' Count number of Y values For Each Item In Y CountY = CountY + 1 Next Item
If CountX >= 2 Then GoTo 10 ' Error not enough values so end calculation Msg = "Need at least 2 values of X" Ans = MsgBox(Msg, vbOKOnly) Interp = "Error" GoTo 400
10 If CountX = CountY Then GoTo 100 ' Error should be equal number of X and Y values Msg = "Need equal number of X & Y values" Ans = MsgBox(Msg, vbOKOnly) Interp = "Error" GoTo 400
100 If Xe > X(1) Then GoTo 200 ' Xe less than smallest X Interp = Y(2) - ((Y(2) - Y(1)) / (X(2) - X(1)) * (X(2) - Xe)) GoTo 400
200 If Xe < X(CountX) Then GoTo 300 ' Xe greater than largest X Interp = Y(CountX - 1) + ((Y(CountX) - Y(CountX - 1)) / (X(CountX) - X(CountX - 1)) * (Xe - X(CountX - 1))) GoTo 400
300 For Item = 1 To CountX If Xe >= X(Item) And Xe <= X(Item + 1) Then GoTo 310 Next Item 310 Interp = (Y(Item + 1) - Y(Item)) / (X(Item + 1) - X(Item)) * (Xe - X(Item)) + Y(Item)
400 ' End Function
Start A New Thread
