Variable feed oil water separation using a belt separator
I was wondering if anyone had suggestions on what type of oil separator would work best in the situation I have been presented.
The waste stream is somewhat variable in nature and it’s temperature will fluctuate according to seasonal changes (the waste is generated outdoors).  The oils being separated are primarily hydraulic fluids, diesel, and lubrication greases.  Currently a belt type separator is being used and is performing poorly in the cold.
