Noise Level
Noise Level
Noise Level
Can someoane help me with the noise level of the folowing equipments, need for a automotive service:
-Rotary lift(P/N SP015)
-Harvey Blower(P/N BD-14)
-Hotsy Pressure Washer(P/N 982SS)
Iulian
RE: Noise Level
Can you please calrify what sort of help do you want with the noise levels? Do you need the dB measurements?
RE: Noise Level
yes, a decibel chart, noise level/ratings.
companies usualy did such measurements and provide catalogues with this charts/tables.
RE: Noise Level
I would suggest to try getting them from the manufacturer?
If the equipment is installed then you may record the dB levels with a sound level meter.
