What is an Isotensoid?
I need to design a cylindrical pressure vessel from carbon fiber. In the literatur everybody recommends to use an isotensoid form at the ends of the cylinder.
Can anybody tell me, what this is and where I can find a mathematical formula for this?
Thank you.
Klaus
RE: What is an Isotensoid?
When I first came across this word, I did a little search and following are the clues found.
Definition: A filamentary structure in which there exists a constant stress in any given filament at all points in its path.
(This talks about constat tensile stress)
For description
http://www.adoptech.com/pressure-vessels/main.htm
An excel spreadsheet for Isotensoid design
http://www.process-research.com/DOME.xls
For some mathematical insights
file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Temporary%20Internet%20Files/Content.IE5/61KRGBOD/331,2,Filament Wound Composite Pressure Vessel - Geodesic Dome Design
You may get some help if you consult any FRP pressure vessel manufacturer.
