types of pumps
types of pumps
types of pumps
need a pump that is able to suck water from underground pit
with a flowrate not less than 143m/h.
RE: types of pumps
lwazi:
You are telling us that you need a fairly common size, vertical, well pump.
Do you want us to know something else?
Art Montemayor
Spring, TX
RE: types of pumps
Is there any piping system involved? Or you just follows what Montemayor said.
Hans in Kitchener,Ontario
RE: types of pumps
As the flow rate is quite high, i think it has to be a centrifugal pump. Now, the choice depends on the readily available pump manufacturer's specification. Better consult any textbook. find out about NPSH and other stuff.
NO PAIN, NO GAIN!!
