How to get the nodal stress results
In a 3D model, I can not get the nodal stress results inside the model even I choose the element option "nodal stress output". I can get the nodal displacements results.
Maybe this is simple question, but I can not get it through.
RE: How to get the nodal stress results
give us the dimension and loading of you problem then we'll compare your answer will our answer.
Hello, Lucy1995!
What element types do you use?
It is possible if your model contains 3D beams to be necessary to display elements based on real constant descriptions in order to see any kind of stresses. A good verification is to list nodal stresses and see what values do you get.
Teoretically, if you get nodal displacements, you get strains (by derivative) and after that by Hooke law the stresses.
If it is possible, send me the input file and I 'll try to fix it for you. (use the mail adress j_onisoru@yahoo.com )
Best regards,
Justin Onisoru
Scientific Researcher
Romanian Academy
Institute of Solid Mechanics
Ctin Mille 15
P. O. Box 1-863
Bucharest 010141
tel +40 21 3153810
fax +40 21 3157478
Romania
