Range("A12").Value = Application.HLookup(1, "H12:EZ12", 1, T
I am in VB and trying to run the following using the excel function hlookup
Range("A12").Value = Application.HLookup(1, "H12:EZ12", 1, True)
but my out put is
Range("A12").Value = error 2015
can any one see what is wrong.  I am at the end on my rope I am not sure what to try
thanks
RE: Range("A12").Value = Application.HLookup(1, "H12:EZ12", 1, T
The second argument of HLOOKUP must be a range, not a string variable, so:
    Range("A12").Value = Application.HLookup(1, Range("H12:M12"), 1, True)
Cheers,
Joerd
hlookup is a worksheet function, try:
Range("A12").Value = Application.worksheetfuntion.HLookup(1, Range("H12:M12"), 1, True)
Cheers
