Grading Capacitors
Grading Capacitors
Could somebody send me information about the application of "Grading Capacitors" in power breakers?
This type of capacitors can be used to increase the switching capacity of the breaker.
Thanks in advance,
FernandoCFE
Thanks in advance,
FernandoCFE
RE: Grading Capacitors
Typically, breaker manufacturers will state that X amount of pico-farads are needed within X distance of the breaker to increase the switching capacity of the breaker to a higher level (versus that without capacitors).
Some breaker designs have grading capacitors built internal and others use external capacitors. The external capacitors can be purchased with the breaker are direct from TRV capacitor manufactures, which are typically the same companies that make capacitor voltage transformers, like Ritz or Trench.
