Metric material tolerance
I am looking for some help with metric tolerance allowable on some aluminum and steel. As an example, I need 1.5 mm sheet (.059 inch) and have been offered .061/.062 sheet. My gut feeling is that this is acceptable, per the rules of the contract on this program, if it is within tolerance I can do it, but I have not had luck finding the allowable deviation on metric materials. Thanks for any help or links that would help.
RE: Metric material tolerance
For aluminum sheet, ASTM B209M references ANSI H35.2M for tolerances. I only have ANSI H35.2 (inch-pound units). Again, thickness tolerance depends on strip width, but the ANSI standard allows + and -, not the + only tolerance that ASTM A 568 uses. For a strip width of 39.37 inches, the tolerance would be +/- 0.002 inches (0.05 mm). You can obtain ASTM standards directly from ASTM and ANSI standards from Global Engineering Documents using the following link:
http://global.ihs.com/
