Machined thread strengths
Hello Members,
I am searching for a good site or reference material to help calculate the pull out strength on a threaded section that will be machined into a part. It will terminate in a Grade 8 Nut so I am not as concerned with the nut strength as I am with the machined section.
RE: Machined thread strengths
You might want to post this in one of the Mechanical Engineering forums as someone there might provide better information.  ASTM or SAE might be a place to look as well.
http://www.astm.org
http://www.sae.org
