ProE WildFire Selection
hi all
I am currently trying to switch to Proe Wildfire. I got into trouble when I tried to use query select or other selection options. Somehow I got the option when I right clicked . But it didn't came up again afterwards. Does somebody have an idea of how to do it?
thanks
Nikhil
RE: ProE WildFire Selection
There is no query-select (as in 2001 and prior), but you can do the same thing by RMB repeatedly until your feature/line/... turns cyan. Then LMB to activate it (turns red).
If you go to  http://www.mss-ptc.com, you can find some tutorials and also a helpful cheat sheet for the mouse commands for BrushFire.
John Petty
Sr. Mech. Designer/ FEA Analyst
Clarke-Alto
