Over voltage fault on drive.
Hi there
We are using an drive on a hoist for a depalletiser. When 'down' is selected the drive trips on over voltage. Probably due to the weight causing this. Can one set something on the drive to prevent this from tripping out? Or any other suggestions please?
We are using the Allen Bradley Powerflex4 3.7KW
RE: Over voltage fault on drive.
http://www.ab.com/drives/powerflex/pf4/index.html
for tech support
