Steam Costs Cogeneration
Anybody know how i can calculate the marginal costs of steam generated through cogeneration or have any rules of thumb?  ($ per unit of usable heat energy)
RE: Steam Costs Cogeneration
What kind of cogeneration? Try posting a little more information about your proposed system. Clearly the cost of your fuel will be a factor.
The natural gas price is approximately $4/mmbtu and the pressure of the steam is about 125 psig.  I don't know what the temperature of the feedwater would be.
If you're already burning gas to generate electricity, well, then the marginal cost of the steam is exactly zero.
Am I missing the point?
If you prefer to allocate costs to steam and electricity, then you could do something like this:
fuel charge x (kW of heat)/(kW of elec + kW of heat)= cost of heat
Peebee,
"....exactly zero".
If only it were true! Demin water, feedwater treatment chemicals, cooling tower make-up water, more chemicals, etc all need to be factored in. Sadly none are free.
