How do you design a 120VDC Permanent Magnet DC Motor?
Most of the PMDC motors that I see are designed for 24VDC. From what I read, a PMDC motor can be made to run at 180VDC(peak). What changes in construction of the motor are need to support higher input voltages?
RE: How do you design a 120VDC Permanent Magnet DC Motor?
http://www.reliance.com/pdf_elements/c401/
for more info
