PC User Name
PC User Name
PC User Name
Is there a command which access the PC user name in Visual Basic?.  I want to use it for the file name when generating reports created in VB
Thanks for your help.
RE: PC User Name
You can access the login name using several methods.
Via Windows API (preferred and most reliable method)
Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
Public Sub Main()
  Dim sUser As String
  Dim lpBuff As String * 1024
  'Get the Login User Name
  GetUserName lpBuff, Len(lpBuff)
  sUser = Left$(lpBuff, (InStr(1, lpBuff, vbNullChar)) - 1)
  MsgBox "Login User: " & sUser
End Sub
Via Environment Variables:
Sub Main()
  Dim sUser As String
  sUser = VBA.Environ("USERNAME")
End Sub
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
RE: PC User Name
is there any macro that allows a random extraction from a particular kind of distribution (normal, binomial, etc) and put that number in a cell so it could be changed pressing F9?
thanks
RE: PC User Name
' API function for getting user name
Public Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
'   Get user name
Public Function GetAccount() As String
    Dim cName As String
    Dim cSize As Long
    cName = Space(255)
    cSize = 255
    If GetUserName(cName, cSize) <> 0 Then
        GetAccount = Left(cName, cSize - 1)
    Else
        GetAccount = ""
    End If
End Function
dongxiao PEng
http://www.cadtool.net
