Corrosion rates of Carbon Steel in Sulphuric/Chloride environment ?
does anybody know where I can get an idea of corrosion rates of Carbon Steel ? Specifically in a high temp, chloride sulphuric acid environment?
A special lining on a tank has failed due to large particle erosion. The steel shell is suspected to be exposed and I would like to be able to get a rough estimate of expected time of tank failure.
Ronan
Ronan
RE: Corrosion rates of Carbon Steel in Sulphuric/Chloride environment ?
If the acid is hot as you indicated, I'm afraid you may find out how corrosive it can be before you get the MTI literature.
