Perpendicular bearing on top and bottom wood plates
I am designing a 4 story wood building (26' long wood trusses on both sides of 6' wide corridor). The trusses will be bottom bearing at the corridor walls-not sure yet if I will use dimension lumber or trusses over the corridor. The axial load on the bottom story results in perpendicular to grain bearing stress from 2x6 studs on the top and bottom plates of about 800 p.s.i., which is roughly double the allowables for S-P-F or Hem-Fir commonly used in this area. I could go with Doug-Fir, which will increase the allow perpendicular to grain bearing stess to 625 p.s.i. and call it good. I wonder though if I am worrying about something that is commonly not considered. This is somewhat like the discussion some time age concerning the ability of the double top plates to span between studs when there is a load applied between the studs. I have a gun to my head concerning costs on this project (as usual), and don't want to be any more anal than absolutely necessary. Any thioughts would be greatly appreciated.
RE: Perpendicular bearing on top and bottom wood plates
Would you care to elaborate on that while waiting for your answer?
Thank You
See the thread "Wood top plate capacity" There was considerable discussion on this topic.
