Looking for 1968 codes
Does anyone have a contact where old codes can be purchased?  I have searched the ASME web site but have not had any luck yet.
RE: Looking for 1968 codes
Might try Brown's Technical Book store in Houston, it's been recommended here several times.
I don't have a web address, Google should get it for you pretty quick though.
Scott,
I hope you have all the addenda taped on properly as we used to say according to code.
Hi, Scott:
Pages for Table UCS-23 attached tp Sec VIII 1965 Ed, except page 102 you had sent to me in August.
Thanks a lot,
One question:
Why do you guys need outdated editions of the ASME Code? Can't you use just use the most recent edition?
-Christine
Christine74,
This all stems from rerating a vessel according to NBIC.
First try to get the original calculations from the manufacturer if not you have to have a PE acceptable to the inspector recalculate the original.
Without typing it all out, you have to establish the reratings according to the code used when the vessel was built or you have start from scratch and recalculate according to the latest code if all essential details are known. If all details are known they usually require recalculation according to the latest code.
Check the inspection records to if see if the vessel is fit for service and the pressure test according to code that was used to rerate the vessel.
In others if every thing is in order you can rerate the vessel under the code that it was built.
All the time the AI is looking over your shoulder.
Somebody get on me if they have changed this as I'm several years out of service.
Unclesyd,
You got it, it sounds like you have done this in the past.
The only thing I would like to add is that as of the more recent ASME Sec VIII Div 1, which permits the use of higher allowable stress values. These higher values can not be used for in rerating a pressure retaining item constructed before the 1968 Edition of ASME Sec VIII Div 1.
NBIC Interpretion 98-14 will also have other minimum criteria for rerating to a later edition/addenda which permits higher allowable stress values.
QAScott
Try Global to purchase "old" asme codes http://global.ihs.com, you may have to call for older codes 800-854-7179
The NBIB has the old codes. You can purchase from them.
As requested from the 1968 ASME VIII Code...
For SA515 Grade 70, the allowable stress, S = 17,500 psi in the range of -20F to 650F.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Thanks Steve.
I was afraid that was the answer.
Basically the numbers crunch to the tank being designed with an allowable stress of somewhere around 22,000 psi in order to get to the fabricated thickness. I have a U1 form, the drawings, no calcs, and now have to figure out what was done 34 years ago. Of course the manufacture is out of business.
Anyone run into this type of problem before?
Fzob,
I run into this type of problem frequently, but not to the extent that you are suggesting.  Often, my problems tend to be centering around the confusion of joint efficency for seamless heads.
Steve Braune
