Validating user input
Does anyone have a function similiar to Visual Basic's "IsNumeric" for Fortran? I'm trying to validate input from a dialog box and find the READ statements IOSTAT and ERR kind of klunky.
RE: Validating user input
Dan
www.dtware.com
SUBROUTINE Validate_Real_k8 ( StrNum, value, valid )
! Check to see that a character string represents a valid real number
! Valid real numbers have the following attributes:
! They are representable by the fortran compiler used with this code.
! ie. No error is flagged when attempting to use a READ statement on
! the data, <StrNum>.
! They do NOT begin or end with the any of the following letters:
! eEdDqQ
! They do not contain embedded blank characters.
! If <StrNum> is all blanks, that is still considered a valid number.
! Input:
! StrNum = Character string which is supposed to represent a valid
! real number. StrNum is not altered by this routine.
! StrNum may be up to 50 character digits (including decimal, etc)
! Output:
! valid = .true. if num is a valid real number or is all spaces.
! = .false. otherwise.
! value = Numeric value from StrNum if valid is .true.
! = 0.0 if the value from StrNum if valid = .false.
! = A variable with a Kind Type of "K8"
! Uses:
! KindTypes = module holding valid kind type parameters
USE KindTypes
IMPLICIT NONE
Character(*), intent(in) :: StrNum
Real(k8), intent(inout) :: value
Logical, intent(out) :: valid
Character(Len(StrNum)) :: num
Integer :: io
Character(1) :: fd, ld
num = ADJUSTL ( StrNum )
Read ( num, '(F50.0)', iostat=io ) value
IF ( io /= 0 ) THEN
! the entered value is not a valid 'real' number
valid = .false.
value = 0.0
RETURN
END IF
io = Len_Trim ( num )
fd = num(1:1) ! first digit
ld = num(io:io) ! last digit
IF ( fd=='e' .OR. fd== 'E' .OR. ld=='e' .OR. ld== 'E' .OR. &
fd=='d' .OR. fd== 'D' .OR. ld=='d' .OR. ld== 'D' .OR. &
fd=='q' .OR. fd== 'Q' .OR. ld=='q' .OR. ld== 'Q' .OR. &
INDEX(num(1:io),' ') /= 0 ) THEN
! Some compilers will accept a real number starting or ending
! with just a 'd' or an 'e'. I don't consider this a valid entry
! LF95 ver 5.5 does this. Also, LF95,5.0 allows q or Q to be
! used to denote exponentiation just as E and D are used.
valid = .false.
value = 0.0
ELSE
valid = .true.
END IF
END SUBROUTINE Validate_Real_k8
