Re Sizing Work Planes in Assemblies
How can you re-size a work plane created in an asssembly?  In a part one can grab the corners and drag them to the size desired.  Why can't one do the same thing in an assembly.
RE: Re Sizing Work Planes in Assemblies
Change your select filter to Faces & Edges.  Then select and resize as needed.  Rememebr to change the select filter back to Components before you drive yourself nuts trying to slect a part..
Sean Dotson, PE
Inventor Tutorials & More
www.sdotson.com
