Macro Switch between Workbooks
Macro in one xls file opens file to process using Application.FindFile. It extracts data and outputs it in a macro opened txt file. How do I switch between files? I obviously know the name of the file the macro is in and the output file but I can pick any file to process with the .Find. How do I pass the macro opened filename to the macro so I can "Workbooks("???.xls").Activate"?
The user might have already opened other workbooks so "Workbooks("BOOK?").Activate" won't work since I don't know what number the latest one used.
RE: Macro Switch between Workbooks
Roger
For each W in Application.Workbooks
Debug.Print W.Name, W.FullName
Next W
Maybe this helps you along a bit
Cheers,
Joerd
On Error Resume Next
Workbooks("Process.xls").Close SaveChanges:=False
Kill "Process.xls"
On Error GoTo 0
ActiveWorkbook.SaveAs FileName:="Process.xls"
I closed a file name if open, deleted it and then saved as a name I've chosen. Now I'm sure of the name. Your's would show me all the names but it wouldn't tell me which one the user just opened.
