Rendering in 2D
Rendering in 2D
Rendering in 2D
Hello everyone,
Is there a way to render in 2d in AutoCAD, or do i have to transfer the drawing to Photoshop or other related programs?
Juice
RE: Rendering in 2D
The closest thing I can think of to "render" in 2D would be "superhatch" from the Express Tools.  Use "Image" for the pattern type, and choose .bmps, .gifs, .etc that you can download from the web to use as materials.
Flores
RE: Rendering in 2D
If you draw using regions you can apply shading and materials...
RE: Rendering in 2D
I might be off base (I haven't tried it myself), but have you tried the 3D Face option?
RE: Rendering in 2D
I think true rendering requires a face or region to apply the texture or "look" you want.  I think Drawf901151 is correct, you might need a face to use true rendering.  Autocad has some trick feature pasting images, but that might not be applicable here.
