Siemens CP343-1
Siemens CP343-1
Hi there all Siemens freaks,
I'm testing an CP343-1 (industrial ethernet) and I slipt into a problem. I'm using a Cp343-1 ver 2.1 and the version in my step 7 software for the hardware selection of the CP-card is version 2.0. My Cp-card stays in stopmode and it's producing an system failure (SF). When I look into the diagnostics I get the message fatal configuration error. The card is still in the factory settings. Do you think that this fault is the result of the version differences? Anyone ever encountered the same problem?
thanks in advance
thanks in advance
RE: Siemens CP343-1
