Referencing Rows to delete blank Rows
I want to delete blanks row in a file that I am reading in so I check for blank cells.  I then try to slect the row by the row number. this is where it hangs up.
CURRENT_ROW = 7
Rows("CURRENT_ROW:CURRENT_ROW").Select      <= hangs up
because I know that
Rows("7:7").select
works
any help would be great thanks
RE: Referencing Rows to delete blank Rows
Try this line
rows(current_rows).delete
Hope this helps!
maybe only a drafter
but the best user at this company!
You can also try this to delete all the empty rows in the used portion of a spreadsheet.
Sub DeleteEmptyRows()
    LastRow = ActiveSheet.UsedRange.column - 1 + ActiveSheet.UsedRange.Rows.Count
    For r = LastRow To 1 Step -1
        If Application.CountA(Rows(r)) = 0 Then Rows(r).Delete
    Next R
End Sub
I'm just looking back over my threads for filing purposes and just found a better way to do this. I know it's a couple of months later but someone may find this useful.
Sub Macro1()
Columns("A:A").SpecialCells(xlCellTypeBlanks).EntireRow.Delete
End Sub
Hope this helps.
